Boot and stability issue when USB drive is attached
I noticed that the rubik pi will not reboot if a USB drive is attached. I can however mount and use the drive after I boot. The final part of the boot log contains the following:
[ OK ] Started systemd-ask-password-conso…equests to Console Directory Watch.
[ OK ] Reached target cryptsetup.target - Local Encrypted Volumes.
[ OK ] Found device dev-ttyMSM0.device - /dev/ttyMSM0.
[ OK ] Found device dev-disk-by\x2dlabel-…st.device - H9QT0G6CN6X146 persist.
[ OK ] Found device dev-disk-by\x2dlabel-…evice - H9QT0G6CN6X146 system-boot.
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.MXF.1.0.c1-00312.1-KODIAKLA-3
S - IMAGE_VARIANT_STRING=SocKodiakLAA
S - OEM_IMAGE_VERSION_STRING=be0390be3c9d
Another issue is that “parted -l” will reset the device if the usb drive is attached. My external usb drives are not recognized when attached to the USB-A ports.
May I confirm which version you are currently using—Ubuntu Server, Ubuntu Desktop, or another distribution?
Ubuntu server, this is the specific image I installed: ubuntu-24.04-preinstalled-server-arm64+rubikpi3-20250912-127.img
The command used to install was: ./qdl --storage ufs prog_firehose_ddr.elf rawprogram*.xml patch*.xml
The md5sum of the os-image:
68658fcf93b7e86ca822a8b79fcf5a4b ubuntu-24.04-preinstalled-server-arm64+rubikpi3-20250912-127.img
May I confirm whether you have switched to the root user?
Could you kindly share the detailed information of the USB device you are using, along with its purchase link?
Would you also be able to provide the test commands and step-by-step procedure you followed?
I was not root but this command requires sudo in order to produce output.
This is the device spec page: Portable SSD T9 2TB USB 3.2 | Samsung US
Other output:
lspci
0000:00:00.0 PCI bridge: Qualcomm Technologies, Inc SM8250 PCIe Root Complex [Snapdragon 865/870 5G]
0000:01:00.0 USB controller: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller (rev 03)
0001:00:00.0 PCI bridge: Qualcomm Technologies, Inc SM8250 PCIe Root Complex [Snapdragon 865/870 5G]
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 04e8:61fd Samsung Electronics Co., Ltd PSSD T9
uname -a
Linux ubuntu 6.8.0-1056-qcom #57-Ubuntu SMP PREEMPT_DYNAMIC Tue Oct 21 15:36:21 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
/usr/sbin/parted --version
parted (GNU parted) 3.6
Copyright (C) 2023 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later https://gnu.org/licenses/gpl.html.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by http://git.debian.org/?p=parted/parted.git;a=blob_plain;f=AUTHORS.
The output begins and seems to crash when it hits the drive:
sudo parted -l
Model: SKhynix H9QT0G6CN6X146 (scsi)
Disk /dev/sda: 123GB
Sector size (logical/physical): 4096B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 efi
2 538MB 569MB 31.5MB ext4 persist
3 569MB 123GB 122GB ext4 writable
Disk /dev/sdb: 21.0MB
Disk Flags:
1 24.6kB 3715kB 3690kB xbl_a hidden, no_automount
2 3715kB 4239kB 524kB xbl_config_a hidden, no_automount
3 4239kB 7930kB 3690kB xbl_b hidden, no_automount
4 7930kB 8454kB 524kB xbl_config_b hidden, no_automount
Disk /dev/sdc: 21.0MB
Disk Flags:
Disk /dev/sdd: 33.6MB
Disk Flags:
1 24.6kB 131kB 106kB ALIGN_TO_128K_1
2 131kB 262kB 131kB cdt hidden, no_automount
3 262kB 1311kB 1049kB ext2 usb_fw hidden, no_automount
4 1311kB 2359kB 1049kB ddr_a
5 2359kB 3408kB 1049kB ddr_b hidden, no_automount
Disk /dev/sde: 2684MB
Disk Flags:
1 24.6kB 549kB 524kB aop_a hidden, no_automount
2 549kB 67.7MB 67.1MB dtb_a hidden, no_automount
3 67.7MB 67.9MB 262kB apdp_a hidden, no_automount
4 67.9MB 70.0MB 2097kB xbl_ramdump_a hidden, no_automount
5 70.0MB 75.3MB 5243kB uefi_a hidden, no_automount
6 75.3MB 79.5MB 4194kB tz_a hidden, no_automount
7 79.5MB 87.8MB 8389kB hyp_a hidden, no_automount
8 87.8MB 92.0MB 4194kB mdtpsecapp_a hidden, no_automount
9 92.0MB 126MB 33.6MB mdtp_a hidden, no_automount
10 126MB 126MB 131kB devcfg_a hidden, no_automount
11 126MB 126MB 81.9kB qupfw_a hidden, no_automount
12 126MB 128MB 2097kB uefisecapp_a hidden, no_automount
13 128MB 130MB 2097kB imagefv_a hidden, no_automount
14 130MB 130MB 131kB shrm_a hidden, no_automount
15 130MB 130MB 32.8kB multiimgoem_a hidden, no_automount
16 130MB 131MB 1049kB cpucp_a hidden, no_automount
17 131MB 131MB 262kB qweslicstore_a hidden, no_automount
18 131MB 132MB 524kB aop_b hidden, no_automount
19 132MB 132MB 262kB apdp_b hidden, no_automount
20 132MB 199MB 67.1MB dtb_b hidden, no_automount
21 199MB 201MB 2097kB xbl_ramdump_b hidden, no_automount
22 201MB 207MB 5243kB uefi_b hidden, no_automount
23 207MB 211MB 4194kB tz_b hidden, no_automount
24 211MB 219MB 8389kB hyp_b hidden, no_automount
25 219MB 223MB 4194kB mdtpsecapp_b hidden, no_automount
26 223MB 257MB 33.6MB mdtp_b hidden, no_automount
27 257MB 257MB 131kB devcfg_b hidden, no_automount
28 257MB 257MB 81.9kB qupfw_b hidden, no_automount
29 257MB 259MB 2097kB uefisecapp_b hidden, no_automount
30 259MB 261MB 2097kB imagefv_b hidden, no_automount
31 261MB 262MB 131kB shrm_b hidden, no_automount
32 262MB 262MB 32.8kB multiimgoem_b hidden, no_automount
33 262MB 263MB 1049kB cpucp_b hidden, no_automount
34 263MB 263MB 262kB qweslicstore_b hidden, no_automount
35 263MB 263MB 4096B SYSFW_VERSION hidden, no_automount
36 263MB 263MB 4096B recoveryinfo hidden, no_automount
37 263MB 263MB 4096B devinfo hidden, no_automount
38 263MB 280MB 16.8MB questdatafv hidden, no_automount
39 280MB 311MB 31.5MB qmcs hidden, no_automount
40 311MB 312MB 1049kB dip hidden, no_automount
41 312MB 346MB 34.2MB splash hidden, no_automount
42 346MB 346MB 4096B limits
43 346MB 346MB 4096B limits-cdsp
44 346MB 348MB 1049kB toolsfv hidden, no_automount
45 348MB 356MB 8389kB logfs hidden, no_automount
46 356MB 398MB 41.9MB quantumsdk hidden, no_automount
47 398MB 935MB 537MB logdump hidden, no_automount
48 935MB 935MB 28.7kB secdata hidden, no_automount
49 935MB 935MB 524kB quantumfv hidden, no_automount
50 935MB 936MB 1049kB catecontentfv
51 936MB 971MB 34.2MB vm-data hidden, no_automount
Disk /dev/sdf: 210MB
Disk Flags:
1 24.6kB 3170kB 3146kB modemst1 hidden, no_automount
2 3170kB 6316kB 3146kB modemst2 hidden, no_automount
3 6316kB 9462kB 3146kB fsg hidden, no_automount
4 9462kB 9593kB 131kB fsc hidden, no_automount
Thank you for your response. We will sync this issue internally and keep you informed of any developments.
