Crashing while running: cargo install --version 0.65.1 bindgen-cli
This is a high load operation that crashes the target. I’ve logged what see after the crash:
 124 D -         0 - devcfg init^M
 125 B -    491538 - PMIC A:2.0 B:1.0 C:2.2 I:1.0^M
 126 B -    493063 - PM: PM_DT_PARSING_ERR: charger^M
 127 B -    496692 - PM: PM0 0x80800^M
 128 B -    499986 - PM: PM1 0x60^M
 129 B -    502945 - PM: PM2 0x60^M
 130 B -    505629 - PM: PM8 0x80008^M
 131 B -    508465 - PM: GP_FAULT7 on Tokei^M
 132 B -    511241 - PM: OVLO|UVLO on Amberjack^M
 133 B -    514840 - PM: OVLO|UVLO on Palani^M
 134 B -    518774 - PM: PON by PWR key DEB^M
 135 B -    522434 - PM: PON by SMPL^M
 136 B -    775645 - PM: SET_VAL:Skip^M
 137 B -    775676 - PM: Verifying PON-Trigger specific configurations & current PON-Trigger^M
 138 B -    784429 - PM: All PON-Trigger specific configs verified. Proceeding to BOOT^M
 139 B -    794189 - PM: PSI: b0x06_v0x3f^M
 140 B -    795806 - PM: OEM_PSI Start^M
 141 B -    797788 - PM: OEM_PSI Done^M
 142 B -    800777 - PM: Device Init # SPMI Transn: 15415^M
 143 D -    321684 - pm_device_init, Delta^M
 144 B -    808616 - pm_driver_init, Start^M
 145 B -    820084 - PM: Driver Init # SPMI Transn: 520^M
 146 D -      7991 - pm_driver_init, Delta^M
 147 B -    825726 - PM: Battery ID: 9946Ohm^M
 148 B -    828227 - PM: debug board connected^M
 149 B -    831887 - vsense_init, Start^M
This
VS what I see after a normal, sudo reboot now:
2178 D -        30 - devcfg init^M
2179 B -    405284 - PMIC A:2.0 B:1.0 C:2.2 I:1.0^M
2180 B -    406809 - PM: PM_DT_PARSING_ERR: charger^M
2181 B -    410621 - PM: Reset by PSHOLD^M
2182 B -    413702 - PM: Reset Type: Hard Reset^M
2183 B -    665296 - PM: SET_VAL:Skip^M
2184 B -    665327 - PM: Verifying PON-Trigger specific configurations & current PON-Trigger^M
2185 B -    674080 - PM: All PON-Trigger specific configs verified. Proceeding to BOOT^M
2186 B -    683840 - PM: PSI: b0x06_v0x3f^M
2187 B -    685457 - PM: OEM_PSI Start^M
2188 B -    687439 - PM: OEM_PSI Done^M
2189 B -    690428 - PM: Device Init # SPMI Transn: 15289^M
2190 D -    297619 - pm_device_init, Delta^M
2191 B -    698267 - pm_driver_init, Start^M
2192 B -    709735 - PM: Driver Init # SPMI Transn: 520^M
2193 D -      7991 - pm_driver_init, Delta^M
2194 B -    715377 - PM: Battery ID: 9944Ohm^M
2195 B -    717878 - PM: debug board connected^M
2196 B -    721538 - vsense_init, Start^M
I’ve attached a fan, which never starts. I tried Desktop and Sever versions.
The clues are whatever PM[0128] and GP_FAULT7 messages. What do those mean?
The putty log is attached:
putty.txt (309.5 KB)
Note to self, “Stop buying cheap USB charging bricks!”
Crash problem appears to be resolved using a better USB hub. Still wondering what is up with the fan not working.
Could you please use different chargers to power the device and see if it can make the fan work. For example, mobile phone or laptop chargers.
