Debian 13 ver 1.1 - missing patch0.xml
Get Started | RUBIK Pi Documentation
Flashing RUBIk Pi 3 Debian 13 Image Version 1.1 is not working.
Above document provides the following instruction:
\QDL.exe prog_firehose_ddr.elf rawprogram0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml rawprogram6.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml patch6.xml
However, patch0.xml does not exist in the RUBIK Pi 3 Debian 13 Image Version 1.1
No need for patch0, just delete patch0.xml from the command. The document will be updated later.
\QDL.exe prog_firehose_ddr.elf rawprogram0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml rawprogram6.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml patch6.xml
