Hello. I am trying to use OpenCL to run inference on the Adreno GPU. I was able to use OpenCL successfully on the RUBIK Pi when running the Debian 13 image and Android image.
However, when I switched to the Ubuntu image, I noticed that there is no libOpenCL.so or any related shared objects under /usr/lib. I tried copying the shared objects from the Debian image, but they fail to load. I also tried installing OpenCL packages with ICD support, but OpenCL still does not work on Ubuntu.
Below is the error log I received when using the shared object from the Debian 13 image.
INFO: Created TensorFlow Lite delegate for GPU.
INFO: Loaded OpenCL library with dlopen.
ERROR: clGetPlatformIDs returned -1001
ERROR: Falling back to OpenGL
INFO: Initialized OpenGL-based API.
INFO: Created 1 GPU delegate kernels.
Is there any way to enable OpenCL on the RUBIK Pi when using the Ubuntu image?
