How to install the Qualcomm IM SDK on RUBIK Pi 3 for model inference?
I’m trying to run a quantized model on my RUBIK Pi 3 and it looks like I need the Qualcomm IM SDK for inference.
The problem is, I’m having one of those “blind moments” where I’m reading the docs but just can’t spot the exact steps for actually installing the SDK onto the board.
I already did everything on the host and already have an qauantized model, now I need to install the SDK on the board and just run it by using an source such as an rtsp stream.
where do I start installing the stuff on the board?
Could you kindly confirm whether the documentation you referred to is the one below?
https://docs.qualcomm.com/bundle/publicresource/topics/80-70020-51/qmi-sdk-qsg-landing-page.html?vproduct=1601111740013072&version=1.5&facet=Intelligent_Multimedia_SDK.SDK.2.0&versionId=c1aaa594-abc6-44da-9b8f-3629375cf59e&open_in_browser=true
Regarding the installation of the QIM SDK, we will continue to optimize the user manual in subsequent releases.
I have been using this doc:
I have installed the Debian OS into the board, does it have to be the Qualcomm Linux ?
https://hongyang-rp.github.io/rubikpi-ubuntu-user-manual-test-en.github.io/docs/Document%20Home/ai
You may refer to the documentation above for the time being; the Debian-specific version will be released shortly.
I think it might be simpler and better to just use the model on the Rubik Pi Github.
I used this QIM
