I want to do camera image quality tuning, is there any relevant documentation?
May I inquire which operating system you are utilizing, Linux or Debian?
Could you please specify which Camera Module you are employing?
You may refer to the following documentation:
Linux,Camera Module is imx477
The released Linux 1.1 version has integrated the IMX477 camera tuning content.
ok,We may try other sensors later, such as imx678, to see the effect, so it would be great if you can provide tuning guidance.
The released Linux 1.1 version only integrated the IMX477 camera tuning content.
RubikPi currently does not support IMX678. If you wish to bring up this camera Module on RubikPi, we recommend that you first check the hardware compatibility.
I have 2x IMX477 cameras working with the pi3, using the latest img from thundercomm
The latest release already includes the IMX477 tuning. Could you please provide a detailed description of the specific issues you are encountering?
My application requires 60 Hz stereo streaming, and I am not able to achieve more than 30 FPS. In the qtifmmsrc guide a video_%u device should allow for up to 120 FPS, but in practice I am not able to get anywhere close to this, regardless of the resolution I set.
The IPE capability is slightly above 4K@30FPS, and the video encoder shares the same limitation.
Neither the ISP (IPE) nor the video encoder supports 4K@60FPS.
If you require 60FPS, we recommend reducing the resolution for testing.
I have tried 1920x1080 and I am unable to run at 60 FPS. No resolution I’ve tried works at 60 FPS.
We recommend that you contact the sensor FAE to obtain the corresponding register configuration for 4 Data Lanes for debugging.
If it’s the same issue, we can discuss it only in the following post.
