Updated to V1.2, based on QLI 1.5
a. Code download:
repo init -u https://github.com/rubikpi-ai/rubikpi-manifest -b qcom-linux-scarthgap -m rubikpi-6.6.90-QLI.1.5-Ver.1.2_qim-product-sdk-2.0.1.xmlb. Code compilation:
./rubikpi_build.sh -ac. Package:
./rubikpi_build.sh --zip_flat_build -
ADB and display will only be enabled after changing the password via the serial terminal at startup (default account and password: root rubikpi)
Default display architecture switched to upstream
HDMI OUT currently only supports up to 1920 x 1440 in upstream
DP OUT output in upstream can only output at a very low resolution
Added cameras: IMX290 and OV5647 (untuned)
Removed ROS compilation from the QIMP SDK in favor of the QIRP SDK.
Removed support for the Bluetooth BSA protocol stack.
Updated the pre-installed rubikpi_config tool. Rubikpi_config will pull the latest version from GitHub (GitHub - rubikpi-ai/tools: Burning tools, etc) every time you compile a Yocto project.
