[Mainline][Linux] Running Mainline Linux on RUBIK Pi 3
The mainline plan for RUBIK Pi 3 is in progress:
Linux kernel patch waiting to be merged:
Linux kernel patches waiting to be submitted:
  • HDMI OUT Enable
  • HDMI OUT AUDIO Enable
  • 3.5mm Headphone Jack Enable
  • Camera Enable
Next, I’ll share my method for debugging the Linux mainline.
1. Flash the base version
Flash the Debian or Ubuntu system for RUBIK Pi (GRUB boot is supported. The general boot process is PBL → XBL → UEFI → GRUB → KERNEL → desktop system).
If you are using the QLI version, replace the kernel image within efi.bin and push the kernel ko files compiled from the mainline source to the /lib/firmware directory.
I chose to flash the Debian 13 V1.1 image (available for download at rubikpi.ai) because the Debian system has ADB enabled by default, which makes debugging convenient.
The procedure for the Ubuntu system is the same as that of Debian, so you can choose either one.
For the flashing instructions, refer to the relevant chapter in the user manual at rubikpi.ai.
2. Download the kernel
Use the following command to download the mainline kernel. Please note that this process may take several hours:
git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
Alternatively, use the Google mirror, which will be significantly faster:
git clone https://kernel.googlesource.com/pub/scm/linux/kernel/git/torvalds/linux.git
Switch to the master-next branch for development.
git remote add linux-next https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git
git fetch linux-next
git fetch --tags linux-next
List next-* tags.
git tag -l "next-*" | tail
Create a development branch from the latest tag.
git checkout -b my_local_branch next-20251222
3. Compile the kernel
3.1 Install the cross-compilation toolchain
I am using aarch64-linux-gnu-. aarch64-linux-gnu-gcc is an ARM cross-compilation tool launched by Linaro based on GCC:
sudo apt install gcc-aarch64-linux-gnu
3.2 Modify defconfig
Change the configuration of CONFIG_SCSI_UFS_QCOM from m to y.
CONFIG_SCSI_UFS_QCOM=y
3.3 Compile all
export ARCH=arm64
export CROSS_COMPILE=aarch64-linux-gnu-
make defconfig
make -j`nproc`
3.4 Package the device tree and ko
The following dtb.bin is sourced from the flat package mentioned in Chapter 1. Flash the base version.
mkdir -p dtb_mnt
sudo mount dtb.bin dtb_mnt/
sudo cp arch/arm64/boot/dts/qcom/qcs6490-thundercomm-rubikpi3.dtb dtb_mnt/combined-dtb.dtb
sudo umount dtb_mnt
ko
mkdir modules
INSTALL_MOD_PATH=modules make modules_install
4. Prepare the operating conditions for the mainline kernel
4.1 Push ko to the board
adb push modules/lib/modules/6.17.0-rc6-g465ced7052f5/ /lib/modules
4.2 Push the kernel image to the board
adb push arch/arm64/boot/Image /boot/vmlinuz-mainline
4.3 Push the firmware to the board
  • Push upstream firmware
git clone https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-frimware
cd linux-firmware
mkdir tmp
sudo make install DESTDIR=tmp
adb push tmp/lib/firmware /root
adb shell
rm /lib/firmware -r
cp /root/firmware /lib/
adb push renesas_usb_fw.mem /lib/firmware
adb push brcmfmac43456-sdio.* /lib/firmware/brcm/
adb push BCM4345C5.hcd /lib/firmware/brcm/
4.4 Create initramfs
  1. Push the force-all-qcom-firmware file to the /etc/initramfs-tools/ hooks directory. This script is designed to forcibly package the firmware located in the qcom directory.
adb push force-all-qcom-firmware /etc/initramfs-tools/hooks
adb shell "chmod +x /etc/initramfs-tools/hooks/force-all-qcom-firmware"
  1. Run the following commands. Modify 6.17.0-rc6-g465ced7052f5 as appropriate, or obtain the version from the ko path in Section 4.1 Push ko to the board.
adb push .config /boot/config-6.17.0-rc6-g465ced7052f5
adb shell "mkinitramfs -o /boot/initrd.img-mainline -k 6.17.0-rc6-g465ced7052f5"
4.5 Set the mainline kernel as the boot kernel
Use the following method to change the default loaded kernel and initrd.
adb shell
cd /boot
ln -sf vmlinuz-mainline vmlinuz
ln -sf initrd.img-mainline initrd.img​
update-grub
Alternatively, press C in the serial terminal during the GRUB boot stage to enter GRUB command-line mode (to change the kernel and initrd for the current boot only):
Note that you need to flash the device tree properly. If you want to switch back, you also need to flash the device tree back. root=UUID=..... is the cmd line, which can be modified as needed.
linux /boot/vmlinuz-mainline root=UUID=131450ff-95bc-4791-b611-70855201b0cd rw  console=ttyMSM0,115200n8 pcie_pme=nomsi earlycon ignore_loglevel quiet  splash vt.handoff=7
initrd /boot/initrd.img-mainline
boot
4.6 Flash the device tree
The dtb.bin file is obtained from Section 3.3 Compile all.
Enter fastboot mode to flash:
reboot bootloader
fastboot flash dtb_a dtb.bin
fastboot reboot
Alternatively, use the dd command in the device terminal to flash:
sudo dd if=dtb.bin of=/dev/disk/by-partlabel/dtb_a bs=4M
5. Check the kernel
After booting, execute the following command to check the running kernel version.
uname -r
