If I use the default Linux OS that comes pre-installed on the Rubik Pi3 board, can I still install the Qualcomm IM SDK and run AI/ML tasks such as object detection using models from the Qualcomm AI Hub and a connected camera without any issues?
Also, I’m curious about the differences between the default OS and the system images available on the official website (e.g., RUBIK Pi 3 Linux System Image 1.0 and 1.1). What are the major differences between these versions and the factory-installed one?
–>Generally, there should be no issues.
Should you encounter any problems, you are encouraged to post in the community forums, where our professional technical team will fully assist you in resolving the issues.
–>The Linux System Image versions are generally more refined compared to the factory-installed versions.
