Q1. What is a pre-built package? What is its purpose?
Pre-built packages are a collection of compiled software packages provided by
Thundercomm through its PPA (Personal Package Archive) repository at
apt.thundercomm.com/rubik-pi-3/noble ppa.
They include:
- Hardware drivers and firmware: GPU driver (qcom-adreno), display drivers,
USB controller firmware, etc. specific to the QCS6490 platform
- Multimedia SDK plugins (IMSDK): GStreamer plugins such as qtivtransform
(GPU-accelerated color conversion/cropping), qtimltflite (NPU inference),
qtivcomposer, etc.
- AI runtime libraries: QNN (Qualcomm Neural Network) / SNPE libraries,
AI Engine Direct delegate libraries
- System-level components: Wayland display service, audio HAL, camera HAL, etc.
Purpose: Enables the Rubik Pi 3’s hardware features (GPU, NPU, camera, display,
audio, etc.) to work properly on Ubuntu. It is the foundation for running AI
and multimedia applications.
Installation commands:
git clone -b ubuntu_setup --single-branch https://github.com/rubikpi-ai/rubikpi-script.git
cd rubikpi-script
./install_ppa_pkgs.sh
Upgrade commands:
sudo apt upgrade -y
Reference: Upgrade Canonical Ubuntu to Latest Build | RUBIK Pi Documentation
Q2. Are pre-built packages supported on both Ubuntu Server and Desktop versions?
Yes, pre-built packages support both Server and Desktop versions. Both versions
rely on the same PPA repository:
sudo add-apt-repository ppa:ubuntu-qcom-iot/qcom-noble-ppa
sudo apt update && sudo apt upgrade -y
Version Differences:
Item Server Version Desktop Version
GUI Desktop Env None ubuntu-desktop + gdm3
GPU Driver qcom-adreno1 qcom-adreno1
Graphics Libs Minimal libegl-mesa0, libvulkan1, etc.
Display Service Wayland (CLI) Wayland (GUI)
Pre-built Packages Fully Supported Fully Supported
Reference: FAQ | RUBIK Pi Documentation
Q3. Server version: pre-built package enables passwordless login.
How to revert to original Server version UI/UX?
If desktop environment-related pre-built packages have been installed on the
Server version, causing a graphical interface and passwordless auto-login,
you can restore the pure command-line Server version with these commands:
# 1. Ensure network connection is active
# 2. Execute the following commands to remove the desktop environment
sudo apt update
sudo apt upgrade -y
sudo apt-get install qcom-adreno1
sudo apt-get remove ubuntu-desktop
sudo apt remove gdm3
sudo reboot
This removes the desktop environment and graphical login manager (gdm3),
restoring the pure command-line Server version interface. After reboot, the
system will return to the terminal mode requiring username/password login.
Switching from Server to Desktop version (reverse operation):
sudo apt update
sudo apt upgrade -y
sudo apt install qcom-adreno1- libgbm-msm1- libegl-mesa0 libegl1 libgles2 libglvnd0 libvulkan1
sudo apt install ubuntu-desktop
sudo reboot
Q4. Is it mandatory to install a pre-built package for QNN/SNPE?
Are there alternative ways?
Recommended but not the only way.
— Option 1: Install Pre-built Package (Recommended) —
This is the simplest approach and will automatically install QNN/SNPE runtime
libraries and all dependencies:
cd rubikpi-script
— Option 2: Alternative Development Paths —
Method Description PPA Required?
Qualcomm AI Hub Optimize models in cloud, download to device Partially (base drivers)
LiteRT/TFLite + AI Engine Run quantized models on NPU via TFLite's NPU driver needed
Direct AI Engine Direct delegate
ONNX Runtime Cross-platform AI with Qualcomm Execution NPU driver needed
Provider for NPU
Llama.cpp Pure C++ LLM inference; GPU acceleration GPU driver needed
requires Adreno driver
Qualcomm Genie SDK Generative AI runtime, independent install Base drivers needed
Qualcomm IMSDK Multimedia and AI SDK with GStreamer plugins IMSDK plugins needed
Qualcomm QIRP Robotics SDK, ROS-based modules Base drivers needed
— Important Notes —
Even without installing pre-built packages via PPA, you still need these
base drivers:
- GPU Driver (qcom-adreno) - Required by almost all AI/multimedia features
- NPU/DSP Driver (Hexagon DSP firmware) - QNN/SNPE NPU acceleration depends on this
- GStreamer IMSDK Plugins - Required if using GStreamer pipelines
These base drivers can typically only be obtained through PPA pre-built packages
or full image flashing; manual compilation is very difficult. Therefore, in
practice, it is still recommended to install pre-built packages.
— AI Development Tools/Frameworks Overview —
Tool/Framework Description Link
Edge Impulse Build/train AI models with audio/image/sensor https://www.edgeimpulse.com/
Qualcomm AI Hub Optimize, validate, deploy AI on Qualcomm https://aihub.qualcomm.com/
LiteRT/TFLite Run quantized models on CPU/NPU via AI Engine https://www.tensorflow.org/
ONNX Cross-platform AI with NPU support https://onnxruntime.ai/
Llama.cpp Local LLM execution (GPU + C++ backend) https://github.com/ggerganov/llama.cpp
Qualcomm Genie Generative AI runtime, multimodal workflows https://docs.qualcomm.com/
Qualcomm IMSDK Multimedia and AI SDK, GStreamer plugins https://docs.qualcomm.com/
Qualcomm QIRP Robotics SDK, ROS-based modules https://docs.qualcomm.com/
Reference: Explore Sample Applications | RUBIK Pi Documentation
