Qualcomm’s model zoo publishes GenAI numbers for flagship phones and the X Elite. For the QCS6490 — the chip in the RB3 Gen 2 kit, and the one a lot of us actually build on — there was nothing. So I measured it myself, on real silicon through AI Hub Workbench.
Qwen3-0.6B, Genie path (QNN context binary, w4a16):
Prefill: 1,555 tok/s
Decode: 24.6 tok/s
TTFT: 82 ms (128-token prompt)
Conditions, so you can reproduce or argue with them: official pre-quantized DEFAULT_W4A16 checkpoint, context length 512, prompt chunk 128 (ar128/ar1 split). Per-graph profile times: embedding prompt 392 µs, embedding token 249 µs, transformer prompt 81,916 µs, transformer token 40,472 µs. Device: Dragonwing RB3 Gen 2 Vision Kit (QCS6490, Hexagon v68).
The part that cost me the most time: the stock export in qai-hub-models 0.66.0 cannot produce this model at all. Two separate bugs. The client unconditionally appends an --output_names segment that the compiler then rejects (issue #366), and the llama.cpp route has no quantization recipe for q4_0 (#367). What worked was skipping the exporter and driving the AI Hub API directly — same compile options, minus that one segment. The compile service itself takes the AIMET model fine. Both bugs are fixed upstream in 0.67.0, but the manual chain still works if you’re pinned to 0.66.0.
Verification, since a number without a trail is just a claim: compile jobs jpvne7nmg / j560rmdn5 / jp3rx7lxp / jgkkokv2g, link job jp42m292g, profile jobs j560rkv65 / jglqoz92p / jp42mo62g / j560rjxn5. Full record and method on the HF card (anguoyang/qwen3-0.6b-qcs6490 · Hugging Face) and in qcs-bench (GitHub - anguoyang/qcs-bench: Measured benchmarks and recipes for Qualcomm AI Hub devices - home of the first public GenAI numbers for QCS6490 (Qwen3-0.6B: 1,555 tok/s prefill, 24.6 tok/s decode) · GitHub).
One caveat, stated plainly: these are per-graph profile numbers on the Genie path, not an end-to-end app benchmark. Decode at this model size is memory-bound; don’t expect the prefill ratio to survive contact with a real product.
If you’re sizing an LLM feature for a QCS6490-class board, this is the baseline I wish I’d had. Happy to share the API-driving script details if anyone hits the same export wall.
