Any clues why HDMI isn’t working out of the box on the v14 boards I just received?
Console shows they were shipped with:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 24.04.2 LTS
Release: 24.04
Codename: noble
HDMI OUT will appear approximately one minute after power-on.
Does the device boot up successfully?
Is it accessible via ADB?
Kindly provide a complete dmesg log.
Turns out, there is something incompatible with this particular display (1920x720 wide field of view). If I use another FHD display it is fine with 24.0.2. I tried other OS, and when I boot with Qualcomm linux 1.3, the 720 display works fine though. It just isn’t working with Debian 13 or the Ubuntu 24.0.2 load.
A very quick - fix would be very welcome for me too.
Actually, how to check board version ?
I have HDMI working properly with qualcomm linux 1.1.1, yet it’s not available for me in ubuntu, in current debian (older one works until update) and ubuntu.
Thanks, I’ll try it today.
Looking at the git message, it improves 4k…
I have attempted connection to following monitors, and none was showing anything from my Rubik (their native resolutions, connection over native HDMI, no converters):
2560x1440
1920x1200
1024x600
Also, tried connection through KVM, but this was unsuccessful also with “old” qualcomm linux, which works without kvm
May I confirm the current situation:
Displays with resolutions of 2560×1440, 1920×1200, and 1024×600 work perfectly under the Linux release, but there is no output under Ubuntu and Debian—even after applying the two patches mentioned above. Is this correct?
Could you please provide the dmesg log for further analysis?
@Rosh:
For the quick answer: Yes.
Please disregard my previous statement, as devicetree change did not get saved.
Now… looking at the documentation here:
It would have been nice if someone from Thundercomm would try to follow it (both for cross and native) the path provided verbatim to identify gaps, as in both cases there are steps missing
packages installed
wrong/nonexistent path for (menu)config, and lack of easier hint: fakeroot debian/rules editconfigs
It works with qualcomm linux 1.1.1, but not 1.2, on monitor Dell 1920x1200, not tried other - as it worked. When it stopped working, I tried other monitors. Now I have it still connected to 1920x1200, can easily connect to 1024x600, but I’d prefer to avoid reflashing to 1.1.1 as I do have some work to do… and prefer to stick to one system (preferably ubuntu) if possible.
It worked with debian published around qualcomm linux 1.1.1, but not after updates, there was no ubuntu available at that time.
I can provide dmesg from “not working” as attachment, too long to paste. contact me with my work email (unchanged).
Having the change in-place, with quite up-to-date ubuntu 1920x1200 monitor works, 1024x600 not.
It’s a touchscreen HDMI+USB, dmesg upon connection:
