thanks for repying,
Here in first setup i use, USB type-C to type-A cable. Type-C goes to “HOST” config rubic and Type-A goes to “DEVICE” config rubic.
Configurations “DEVICE” side
root@tnn-service:/sys/kernel/config/usb_gadget# modprobe -r g_ether
root@tnn-service:/sys/kernel/config/usb_gadget# mkdir g1
root@tnn-service:/sys/kernel/config/usb_gadget# l
**g1**/
root@tnn-service:/sys/kernel/config/usb_gadget# cd g1/
root@tnn-service:/sys/kernel/config/usb_gadget/g1# ls
UDC bDeviceProtocol bMaxPacketSize0 bcdUSB **functions** idVendor **os_desc** **webusb**
bDeviceClass bDeviceSubClass bcdDevice **configs** idProduct max_speed **strings**
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo 0x1d6b > idVendor
echo 0x0104 > idProduct
root@tnn-service:/sys/kernel/config/usb_gadget/g1# mkdir strings/0x409
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo "1234567890" > strings/0x409/serialnumber
echo "Rubic" > strings/0x409/manufacturer
echo "MassStorage" > strings/0x409/product
root@tnn-service:/sys/kernel/config/usb_gadget/g1# mkdir configs/c.1/strings/0x409
mkdir: cannot create directory ‘configs/c.1/strings/0x409’: No such file or directory
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo "Config 1" > configs/c.1/strings/0x409/configuration
root@tnn-service:/sys/kernel/config/usb_gadget/g1# mkdir functions/mass_storage.0
root@tnn-service:/sys/kernel/config/usb_gadget/g1# dd if=/dev/zero of=/tmp/test.iso bs=1M count=2048
2048+0 records in
2048+0 records out
2147483648 bytes (2.1 GB, 2.0 GiB) copied, 1.87076 s, 1.1 GB/s
root@tnn-service:/sys/kernel/config/usb_gadget/g1# mkfs.ext4 /tmp/test.iso
mke2fs 1.47.0 (5-Feb-2023)
Discarding device blocks: done
Creating filesystem with 524288 4k blocks and 131072 inodes
Filesystem UUID: ef27c07b-5365-4a17-afe7-58e4a11b23bd
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo "/tmp/test.iso" > functions/mass_storage.0/lun.0/file
root@tnn-service:/sys/kernel/config/usb_gadget/g1# ln -s functions/mass_storage.0/ configs/c.1/f3
root@tnn-service:/sys/kernel/config/usb_gadget/g1# mount -t debugfs none /sys/kernel/debug/
mount: /sys/kernel/debug: none already mounted or mount point busy.
dmesg(1) may have more information after failed mount system call.
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo "" > /sys/kernel/debug/usb/8c00000.usb/mode
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo "device" > /sys/kernel/debug/usb/8c00000.usb/mode
root@tnn-service:/sys/kernel/config/usb_gadget/g1# cat UDC
root@tnn-service:/sys/kernel/config/usb_gadget/g1# echo 8c00000.usb > UDC
root@tnn-service:/sys/kernel/config/usb_gadget/g1# cat /sys/kernel/debug/usb/8c00000.usb/mode
device
Configurations “HOST” side. Since we are using type C
root@rubikpi-0316:/home/ubuntu# cat /sys/kernel/debug/usb/a600000.usb/mode
device
root@rubikpi-0316:/home/ubuntu# echo "host" > /sys/kernel/debug/usb/a600000.usb/mode
host
Connect the USB cable and observer “sudo dmesg -w”
on “HOST” side
[ 1565.295508] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1565.295548] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 4
[ 1565.297714] xhci-hcd xhci-hcd.4.auto: hcc params 0x0230fe65 hci version 0x110 quirks 0x0000008000000010
[ 1565.297788] xhci-hcd xhci-hcd.4.auto: irq 193, io mem 0x0a600000
[ 1565.297975] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1565.297994] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 1565.298013] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 1565.298399] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[ 1565.298413] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1565.298421] usb usb4: Product: xHCI Host Controller
[ 1565.298442] usb usb4: Manufacturer: Linux 6.8.0-1057-qcom xhci-hcd
[ 1565.298451] usb usb4: SerialNumber: xhci-hcd.4.auto
[ 1565.299159] hub 4-0:1.0: USB hub found
[ 1565.299209] hub 4-0:1.0: 1 port detected
[ 1565.299676] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1565.299800] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[ 1565.299811] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1565.299836] usb usb5: Product: xHCI Host Controller
[ 1565.299843] usb usb5: Manufacturer: Linux 6.8.0-1057-qcom xhci-hcd
[ 1565.299849] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 1565.300617] hub 5-0:1.0: USB hub found
[ 1565.300684] hub 5-0:1.0: 1 port detected
[ 1565.536097] usb 4-1: new full-speed USB device number 2 using xhci-hcd
[ 1575.750464] xhci-hcd xhci-hcd.4.auto: xHCI host not responding to stop endpoint command
[ 1575.770639] xhci-hcd xhci-hcd.4.auto: xHCI host controller not responding, assume dead
[ 1575.778775] xhci-hcd xhci-hcd.4.auto: HC died; cleaning up
[ 1575.784534] usb usb4-port1: couldn't allocate usb_device
on “DEVICE” side
nothing on dmesg logs.
check the “HOST” side lsusb
root@rubikpi-0316:/home/ubuntu# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
host
