Unable to Access Ubuntu on Rubik Pi via ADB
I recently flashed Canonical Ubuntu 24.04 on my Rubik Pi using the Qualcomm Launcher, following this guide:
After successfully installing Ubuntu, I was able to access my Rubik Pi 3 via Wi-Fi.
I then tried to use the adb command to access the board. I followed the Ubuntu preparation guide:
When I run adb devices on my Windows 11 laptop, the board is not detected. However, using adb devices with the same cable successfully detects my Android devices.
Could someone please provide guidance on how to access the Rubik Pi 3 via ADB?
The Ubuntu image does not include ADB support by default. Should you require ADB functionality, please install the necessary packages first.
Alternatively, you may connect to the development board via SSH using the following command:
ssh <username>@<ip-address>
Hi Kinkin,
Could you please share which packages need to be installed to use the ADB feature on Rubik Pi with Ubuntu? Additionally, it would be helpful to include this information in the Rubik Pi documentation, as it will benefit many developers.
Another point to note is that the Ubuntu System FAQ includes the question, “How can I install and connect Android Debug Bridge (ADB) on the host?” This may confuse developers into thinking that ADB is already supported on Ubuntu. FAQ | RUBIK Pi Documentation
Thanks, we will provide your feedback.
There is no ADB function on Ubuntu, it needs to be installed through a serial port.
  1. Serial login username Ubuntu password Ubuntu
  2. adb is not supported by default, and additional installation is required to use it
    Use the scp command to push the installation package onto the board and run sudodpkg-i *. deb to install it
    Share file: adb (2). zip
    Cloud disk link: 查看分享
    Extract password: kqu5
