Yocto image does not boot
I followed the guide to build custom Yocto image but once flashed got the following error about I2C PMIC during UEFI phase.
Any idea what to do?
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.MXF.1.0.c1-00254.3-KODIAKLA-1
S - IMAGE_VARIANT_STRING=SocKodiakLAA
S - OEM_IMAGE_VERSION_STRING=ip-10-195-204-27
S - Boot Interface: UFS
S - Secure Boot: Off
S - Boot Config @ 0x00786070 = 0x000000c1
S - JTAG ID @ 0x00786130 = 0x001980e1
S - OEM ID @ 0x00786138 = 0x00000000
S - Serial Number @ 0x00786134 = 0x4f54b62a
S - OEM Config Row 0 @ 0x007841c0 = 0x0000000000000000
S - OEM Config Row 1 @ 0x007841c8 = 0x0000000000000000
S - Feature Config Row 0 @ 0x00784148 = 0x0000000000000000
S - Feature Config Row 1 @ 0x00784150 = 0x0000000000000000
S - Core 0 Frequency, 1516 MHz
S - PBL Patch Ver: 1
D -      6626 - pbl_apps_init_timestamp
D -     39249 - bootable_media_detect_timestamp
D -       818 - bl_elf_metadata_loading_timestamp
D -       704 - bl_hash_seg_auth_timestamp
D -      6856 - bl_elf_loadable_segment_loading_timestamp
D -      4823 - bl_elf_segs_hash_verify_timestamp
D -     17641 - bl_sec_hash_seg_auth_timestamp
D -       811 - bl_sec_segs_hash_verify_timestamp
D -        29 - pbl_populate_shared_data_and_exit_timestamp
S -     77557 - PBL, End
B -     89365 - SBL1, Start
B -    221887 - SBL1 BUILD @ 14:57:07 on Dec 19 2024
B -    226066 - usb: HS: device tree Not available , 0x3
B -    229573 - usb: eud_serial_upd , 0x4f54b62a
D -    234911 - sbl1_hw_init
D -       458 - media_init:1
D -         0 - smss_load_cancel
D -         0 - boot_sail_pbl_edl_check
D -         0 - sail_execute_bist_sequence
B -    251991 - SMSS -  Image Load, Start
D -      4087 - SMSS -  Image Loaded, Delta - (0 Bytes)
D -      1037 - Auth Metadata
D -      5825 - sbl1_xblconfig_init
B -    268156 - XBL Config -  Image Load, Start
B -    272365 - DTB  Found: [pre-ddr][7601f201000000][0]
D -      4514 - boot_pre_ddr_dtb_load
B -    282948 - UFS Device Tree Settings
B -    285083 - UFS Init Speed: HS Enabled 1, Gear 4 2 Lane Rate 2
B -    294843 - UFS Perf Speed: HS Enabled 1, Gear 4 2 Lane Rate 2
B -    301157 - UFS Timeouts(us): fDeviceInit 2500000, UTRD Poll 30000000
D -     55449 - media_init:2
B -    370636 - UFS INQUIRY ID: SKhynix H9QT0G6CN6X146  A002
B -    372740 - UFS Boot LUN: 1
B -    386648 - UFS GEAR: 3
D -     55662 - media_init:3
D -        31 - shrm_load_cancel
B -    395341 - SHRM -  Image Load, Start
D -       671 - Auth Metadata
D -      1342 - Segments hash check
D -     12261 - SHRM -  Image Loaded, Delta - (35752 Bytes)
D -         0 - boot_default_cdt_init
D -       152 - boot_cdt_init
B -    420259 - CDT -  Image Load, Start
B -    423126 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:1
D -     17111 - sbl1_hw_platform_pre_ddr
D -         0 - devcfg init
B -    450027 - PMIC A:2.0 B:1.0 C:2.2 I:1.0
B -    451583 - PM: PM_DT_PARSING_ERR: charger
B -    455426 - PM: PM8 0x4
B -    458872 - PM: xVdd reset
B -    461404 - PM: PON by PWR key DEB
B -    714035 - PM: SET_VAL:Skip
B -    714066 - PM: Verifying PON-Trigger specific configurations & current PON-Trigger
B -    722819 - PM: All PON-Trigger specific configs verified. Proceeding to BOOT
B -    732579 - PM: PSI: b0x06_v0x3f
B -    735080 - PM: OEM_PSI Start
B -    736178 - PM: OEM_PSI Done
B -    739137 - PM: Device Init # SPMI Transn: 15440
D -    301920 - pm_device_init, Delta
B -    747006 - pm_driver_init, Start
B -    758443 - PM: Driver Init # SPMI Transn: 518
D -      7960 - pm_driver_init, Delta
B -    764055 - PM: Battery ID: 9874Ohm
B -    766587 - PM: debug board connected
B -    770247 - vsense_init, Start
D -         0 - vsense_init, Delta
D -    346450 - sbl1_hw_pre_ddr_init
D -         0 - boot_dload_handle_forced_dload_timeout
D -      2928 - sbl1_load_ddr_training_data
B -    795165 - Pre_DDR_clock_init, Start
D -        91 - Pre_DDR_clock_init, Delta
D -     12902 - sbl1_ddr_set_params
B -    806847 - sbl1_ddr_init, Start
B -    810263 - LP4 DDR detected
D -     15189 - sbl1_ddr_init, Delta
B -    825391 - DSF version = 262.0.46
B -    828776 - Manufacturer ID = 6, Device Type = 7
B -    832345 - Rank 0 size = 4096 MB, Rank 1 size = 4096 MB
B -    837194 - Row Hamming DDR
B -    842715 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH0 & CS0
B -    851377 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH0 & CS1
B -    862082 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH1 & CS0
B -    872818 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH1 & CS1
D -     76768 - sbl1_ddr_init
D -        31 - boot_pre_ddi_entry
B -    891301 - do_ddr_training, Start
B -    932476 - DDR: Start of DDR Training Restore
B -    936014 - Current DDR Freq = 1709 MHz
B -    937143 - Max enabled DDR Freq = 2092 MHz
B -    941138 - DDR: End of DDR Training Restore
D -     51057 - do_ddr_training, Delta
D -     58835 - sbl1_do_ddr_training
D -       519 - boot_ddi_entry
B -    956968 - Pimem init cmd, entry
D -      9211 - Pimem init cmd, exit
B -    969595 - External heap init, Start
B -    972492 - External heap init, End
D -     22326 - sbl1_post_ddr_init
D -       213 - sbl1_hw_init_secondary
B -    983198 - DDR -  Image Load, Start
B -    989359 - DTB  Found: [post-ddr][7601f201000000][2201010000000000]
D -      9486 - boot_post_ddr_dtb_load
B -    998722 - usb: UFS Serial - dc312de7
B -   1000766 - usb: fedl, vbus_low
D -      7503 - boot_fedl_check
B -   1007994 - APDP -  Image Load, Start
D -      3203 - APDP -  Image Loaded, Delta - (64 Bytes)
D -         0 - boot_dload_dump_security_regions
D -         0 - ramdump_load_cancel
B -   1024434 - RamDump -  Image Load, Start
D -      3324 - RamDump -  Image Loaded, Delta - (0 Bytes)
D -        31 - boot_update_abnormal_reset_status
D -         0 - boot_cache_set_memory_barrier
D -         0 - boot_smem_debug_init
D -       457 - boot_smem_init
D -        31 - boot_smem_alloc_for_minidump
D -        92 - boot_smem_store_pon_status
D -        30 - sbl1_hw_platform_smem
D -        92 - boot_ddr_share_data_to_aop
D -       488 - boot_clock_init_rpm
D -         0 - boot_vsense_copy_to_smem
D -        31 - boot_populate_ram_partition_table
D -        30 - boot_populate_ddr_details_shared_table
D -       244 - sbl1_tlmm_init
D -         0 - sbl1_efs_handle_cookies
B -   1087203 - OEM_MISC -  Image Load, Start
D -       641 - Auth Metadata
D -       366 - Segments hash check
D -     10675 - OEM_MISC -  Image Loaded, Delta - (5048 Bytes)
B -   1101172 - QTI_MISC -  Image Load, Start
D -      5703 - QTI_MISC -  Image Loaded, Delta - (0 Bytes)
D -        30 - boot_sail_wait_for_bist
B -   1123681 - PM: PM Total Mem Allocated: 8876
D -      7168 - sbl1_pm_aop_pre_init_wrapper
B -   1128256 - AOP -  Image Load, Start
D -       793 - Auth Metadata
D -      1738 - Segments hash check
D -     13816 - AOP -  Image Loaded, Delta - (197074 Bytes)
B -   1145366 - QSEE Dev Config -  Image Load, Start
D -       762 - Auth Metadata
D -       701 - Segments hash check
D -     13054 - QSEE Dev Config -  Image Loaded, Delta - (45056 Bytes)
B -   1167448 - QSEE -  Image Load, Start
D -     18025 - Auth Metadata
D -     23302 - Segments hash check
D -     58591 - QSEE -  Image Loaded, Delta - (4187776 Bytes)
B -   1230827 - DTB: Vibration Enabled
D -      7198 - sbl1_hw_play_vibr
D -        91 - boot_set_device_storage_type
B -   1241685 - SEC -  Image Load, Start
D -      4240 - SEC -  Image Loaded, Delta - (64 Bytes)
B -   1249554 - CPUCPFW -  Image Load, Start
D -     17751 - Auth Metadata
D -     17446 - Segments hash check
D -     50295 - CPUCPFW -  Image Loaded, Delta - (171260 Bytes)
B -   1308877 - QHEE -  Image Load, Start
D -     17416 - Auth Metadata
D -      7107 - Segments hash check
D -     27938 - QHEE -  Image Loaded, Delta - (1515600 Bytes)
B -   1340109 - APPSBL -  Image Load, Start
D -       732 - Auth Metadata
D -     32299 - APPSBL -  Image Loaded, Delta - (4132816 Bytes)
D -         0 - sbl1_save_appsbl_index
B -   1381650 - SBL1, End
D -   1295731 - SBL1, Delta
S - Flash Throughput, 257430 KB/s  (10554644 Bytes,  41207 us)
S - DDR Frequency, 1555 MHz
0       1.453452 Hypervisor cold boot, version: gunyah-8f65fea13 prod (2024-11-06 06:03:49 UTC)
0       1.493302 Failed to register KP
[RM]Resource Manager version: a9201776 (Tue Nov 5 09:20:46 2024 UTC)
[RM]HLOS is RAS handler
[RM]Init completed, disabling UART
0       1.528341 Hypervisor UART is disabled!
UEFI Start     [ 1533]
 - 0x09FC01000 [ 1536] Sec.efi
ASLR        : ON
DEP         : ON (RTB)
Timer Delta : +16 mS
RAM Entry 0 : Base 0x0080000000  Size 0x0039700000
RAM Entry 1 : Base 0x00C0000000  Size 0x0001800000
RAM Entry 2 : Base 0x00C3400000  Size 0x00BCC00000
RAM Entry 3 : Base 0x0180000000  Size 0x0100000000
Total Available RAM : 8059 MB (0x01F7B00000)
Total Installed RAM : 8192 MB (0x0200000000)
Init CPU core 1
  > Scheduler up on Core 1
UEFI Ver    : 6.0.241219.BOOT.MXF.1.0.c1-00254.3-KODIAKLA-1
Build Info  : 64b Dec 19 2024 14:58:24
Boot Device : UFS
PROD Mode   : TRUE
Retail      : TRUE
After Create Event Status (0x0)
ShmBridgeInitialize: enable status 0
PM0: 47, PM1: 63, PM2: 49, PM8: 46,
ERROR:NACK: SA:0x08 Inst:0x0000 0x01
qup_fifo_cancel : Geni command not active : 0x00984000
Failed to detect external I2C PMIC with return value : 26. PMIC is left at default state
ERROR: C90000002:V03000007 I0 5776232E-082D-4B75-9A0E-FE1D13F7A5D9
ASSERT DebugLib.c +78: Format != ((void *) 0)
D -      6633 - pbl_apps_init_timestamp
D -     39208 - bootable_media_detect_timestamp
D -       817 - bl_elf_metadata_loading_timestamp
D -       703 - bl_hash_seg_auth_timestamp
D -      6848 - bl_elf_loadable_segment_loading_timestamp
D -      4825 - bl_elf_segs_hash_verify_timestamp
D -       813 - bl_sec_segs_hash_verify_timestamp
D -        30 - pbl_populate_shared_data_and_exit_timestamp
S -     77518 - PBL, End
B -     86772 - SBL1, Start
B -    214933 - SBL1 BUILD @ 14:57:07 on Dec 19 2024
B -    218959 - usb: HS: device tree Not available , 0x3
B -    222375 - usb: eud_serial_upd , 0x4f54b62a
D -    227530 - sbl1_hw_init
D -       457 - media_init:1
B -    244061 - SMSS -  Image Load, Start
D -      3934 - SMSS -  Image Loaded, Delta - (0 Bytes)
D -      5612 - sbl1_xblconfig_init
B -    259707 - XBL Config -  Image Load, Start
B -    263764 - DTB  Found: [pre-ddr][7601f201000000][0]
D -      4392 - boot_pre_ddr_dtb_load
B -    273981 - UFS Device Tree Settings
B -    276055 - UFS Init Speed: HS Enabled 1, Gear 4 2 Lane Rate 2
B -    285510 - UFS Perf Speed: HS Enabled 1, Gear 4 2 Lane Rate 2
B -    291610 - UFS Timeouts(us): fDeviceInit 2500000, UTRD Poll 30000000
D -     53741 - media_init:2
B -    358954 - UFS INQUIRY ID: SKhynix H9QT0G6CN6X146  A002
B -    360998 - UFS Boot LUN: 1
B -    374509 - UFS GEAR: 3
D -     54015 - media_init:3
B -    382988 - SHRM -  Image Load, Start
D -       153 - boot_cdt_init
B -    393389 - CDT -  Image Load, Start
B -    396164 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:1
D -      9485 - sbl1_hw_platform_pre_ddr
D -         0 - devcfg init
B -    416325 - PMIC A:2.0 B:1.0 C:2.2 I:1.0
B -    417850 - PM: PM_DT_PARSING_ERR: charger
B -    421693 - PM: Reset by PSHOLD
B -    424712 - PM: Reset Type: Warm Reset
B -    428037 - PM: Warm reset count:0x3
B -    431971 - PM: Reset by PSHOLD
B -    435723 - PM: Reset Type: Warm Reset
B -    439047 - PM: Warm reset count:0x2
B -    442951 - PM: Reset by PSHOLD
B -    446733 - PM: Reset Type: Warm Reset
B -    450027 - PM: Warm reset count:0x1
B -    702232 - PM: SET_VAL:Skip
B -    702262 - PM: Verifying PON-Trigger specific configurations & current PON-Trigger
B -    711016 - PM: All PON-Trigger specific configs verified. Proceeding to BOOT
B -    720776 - PM: PSI: b0x06_v0x3f
B -    723277 - PM: OEM_PSI Start
B -    724375 - PM: OEM_PSI Done
B -    727333 - PM: Device Init # SPMI Transn: 15314
D -    323513 - pm_device_init, Delta
B -    735202 - pm_driver_init, Start
B -    746609 - PM: Driver Init # SPMI Transn: 518
D -      7961 - pm_driver_init, Delta
B -    752252 - PM: Battery ID: 9869Ohm
B -    754783 - PM: debug board connected
B -    758443 - vsense_init, Start
D -    368074 - sbl1_hw_pre_ddr_init
B -    778360 - Pre_DDR_clock_init, Start
D -        61 - Pre_DDR_clock_init, Delta
D -      8875 - sbl1_ddr_set_params
B -    791048 - sbl1_ddr_init, Start
B -    794433 - LP4 DDR detected
B -    798002 - PASS1 Cookie =  0xcafe1111
B -    800808 - HAL_DDR_SDI_Recover() start:  DBG PDC Tr = 0x0, First Pass expire = 0x0, First Pass complete = 0x1 , BIMC Alt ARES  = 0x0 , PASS2 Cookie = 0xcafecab0
B -    816149 - SHRM run state = 0x1
B -    819840 - HAL_DDR_SDI_Recover() end : DBG PDC Tr = 0x0, First Pass expire = 0x0, First Pass complete = 0x1 , BIMC Alt ARES  = 0x0 , PASS2 Cookie = 0xcafebabe
B -    834632 - SHRM run state = 0x1
D -     43706 - sbl1_ddr_init, Delta
D -     50599 - sbl1_ddr_init
D -         0 - boot_pre_ddi_entry
B -    847717 - do_ddr_training, Start
D -         0 - do_ddr_training, Delta
D -      6801 - sbl1_do_ddr_training
D -         0 - boot_ddi_entry
B -    861503 - Pimem init cmd, entry
D -       122 - Pimem init cmd, exit
B -    869067 - External heap init, Start
B -    871293 - External heap init, End
D -     16592 - sbl1_post_ddr_init
D -       183 - sbl1_hw_init_secondary
B -    881999 - DDR -  Image Load, Start
B -    888190 - DTB  Found: [post-ddr][7601f201000000][2201010000000000]
D -      9455 - boot_post_ddr_dtb_load
B -    897462 - usb: ser_str_cookie_pid - dc312de7
B -    899628 - usb: fedl, vbus_low
D -      8235 - boot_fedl_check
B -    907466 - APDP -  Image Load, Start
D -      3386 - APDP -  Image Loaded, Delta - (64 Bytes)
D -       610 - boot_dload_dump_security_regions
B -    919453 - TCSR reg value 0x10
D -      4483 - ramdump_load_cancel
B -    927322 - RamDump -  Image Load, Start
D -      1555 - Segments hash check
D -     10217 - RamDump -  Image Loaded, Delta - (187648 Bytes)
B -    946537 - boot_dload_entry
B -    947421 - External heap deinit, Start
B -    949709 - External heap init, End
B -    953735 - External heap init, Start
B -    957425 - External heap init, End
B -   1069848 - usb: init start
B -   1069879 - usb: qusb_dci_platform , 0x22
Please flash “provision” folder first, with checking “provision” check box in Tflash.
Then flash “ufs” folder, unchecking “provision” check box.
Let me know whether it works for you. Thanks!
